Touch screen lag. Did a hard re-set.
You had issue charging the device?
Also not seeing the attached picture you talked about. Maybe it is not showing up on mobile
You need to go to the original post on XDA to see picture .. double click on the hyperlink "Fixed my touch screen problems!" within the post ... this solution did not work for the loss of touchscreen sensitive I am experiencing.
The only good thing about this situation is that I am learning about the inside of a tablet ... also a silver lining / glass half full view! :)
Okay, the only thing that returns touch screen sensitivity is when I totally shut down nearly all running apps.
Mine was also fine for a week playing games etc. then for the first time I had it in car seat for 1.5hr drive with navigation in the late afternoon. ever since then I've had touch issues. and never specifically tried to look for the issue I just noticed I couldn't type.
so did you ever have it in car or hot car?
I have this cup holder in my car - Satechi SCH-121 Cup Holder Mount.
The screen became unresponsive (not completely, but enough to cause an accident while driving) in the car while installed in this mount.
I thought I had squeezed the screen edges too tight with the holder, but it still did it when the grips were released, but still sitting on the soft circle pad.
I went home thinking I had broken it, but it worked fine when I tried it at home. (What a relief!)
I tried it again that night, but without clamping the sides.
There is a plastic sheet that covers the soft circle pad to cover some adhesive.
I removed it to 'stick' the pad down so it wouldn't slide out of the unclamped cradle.
It worked just fine.
So I don't know if it was a grounding issue, a clamping the side issue, or a using it in the sun and heat issue.
I'll do some more experiments and maybe make some videos so I can update everyone about it.
smith-jhone
