Trade in prices
Yep I'm getting the ultra for sure :)
That's not bad at all.
Be careful of the "credit". The $200 samsung store coupon they offered for the Note 10 was utter garbage. Basically, you got to choose between a limited set of overpriced accessories or cases. If it's truly $200 in cash savings, that's a different story.
Thanks for pointing that out .
I'm probably out on this one. Did the S9 and S10 through Samsung the last 2 years and the process was painless on trade-ins, so kudos to Samsung for making it easy both those times. Just ran the early reserve through the Samsung site and only $600 ( which honestly it should be) for my S10. 5G as a truly viable option is at least 12-18 months away at best and there's not enough value in the other product improvements to justify $400 out of pocket for the S20.
I am a huge Samsung fanboy on a variety of products that I own ( 4 TVs, 3 Tablets, 2 Smartwatches, 3 phones, and big a$$ fridge) and no complaints and usually always an early adopter, just not this time around. Enjoy your new S20s everyone!!
It depended on how early you ordered
I did two of the credits for two lines on my note 10+ purchases. And yes they did offer discount packages you could use the money on, but for me at least I was able to buy whatever I wanted to get for the 150 credit.
The 200 could be used towards anything mobile wise. I used mine on a tab s6 keyboard case which was regular priced. Could've also used it on the active 2 as I did a mock order.
I'm curious if it's worth the extra 100.00 to get the 512. On my note 10+ I'm only using 45g of the 256. I keep everything on a micro SD card and I can get a 256 SD card for like 40 bucks. I mean even if I upgraded to 512 I'd probably still keep my photos and important stuff on the sd card anyways.
Which model? The Ultra is 200 dollars more
Dont rely on the SD card as your only means of storage for important stuff because they have been known to fail.
Yeah I know either or can fail but probably more likely the card vs the phone. I haven't bothered with cloud services either and I know Verizon charges a fee for theirs.
Sounds like 128 is more than adequate for you. I'm using 103gb right now but could off load some big files. I'm annoyed that 128 is the base model. Memory isn't that expensive that they couldn't have 256 as a base, especially the Ultra model.
Yeah I agree 256 should have been the standard. I decided to just get the 512 anyways bc it was less then 5.00 a month more.
Love the ultra but think I'm going with the S20+ on this one. I traded my S10+ in for the Note 10+ and regretted the size difference. It doesn't look the much bigger on paper but in the hand is a different story. I hope BB as then on display soon as that might convince me to jump on the ultra.
Also getting $700 for my Note 10+ which might make it manageable.
looks like I'm going to get my S20 from Best Buy. Only thing it looks like I'm not getting are the buds.
gocoronago2021
