transfer photos from camera to sd card without using a pc?
It took me a couple times to figure out how this was done. I have an S5Active, and for some reason pictures started to save in a separate file, one had the camera and sd icon and one just had the camera icon.
In order to put the pictures which are under the file containing only the camera icon, into the file with the camera and SD card icon the following steps should be taken.
Open Apps
Open My FIles
Select Device Storage
Select DCIM
Select Camera
This will display a list of all of the photos in the file marked with the camera icon ONLY.
Tap and hold one of the files and use the Select All option you should see checkmarks next to all of your pics now.
Tap the 3 vertical dots in the upper right and select Move
Select SD Card
Select DCIM
Select Camera
Select Move to Here. It will take a while for the files to download you will know you got it right when you see the loading bar and the % and 1/how many photos you are moving.
I hope this helps I know it was frustrating the hell outta me because my phone kept running outta space and my phone was getting hotter than the hinges on the gates of hell. To prevent this from happening again, simply go to camera settings and scroll down (using your finger there is no scroll bar, tricky)to Storage and select the Storage card instead of save to device.
How do you transfer photos from gallery to SD card pls
How do you fix storage spaces running out
rose1988
