Transformer 3.1 update. Here it is.
What are the first 4 digits of your serial number?
I have discovered that early builds with B40K have more issues than the later builds with B50K.
That is an interesting thought. I wonder if the same holds true for other issues like lightbleed. Mine starts with B50KA and I have no lightbleed at all.
No, I've had three B50K Transformers and they all had some sort of light bleed.
So, if you are powering on your Transformer in a dark room, you don't see any light blotches around any of the edges during the boot process?
None. I specifically went into a windowless room and turned off all the lights to check this. Others have reported no lightbleed also, so I am not alone.
Does anyone know if this update.zip feature works on the eee pad slider sl101 as well?
I have the slider and keep trying but power+upVolume only boots into a black screen with a green android with a yellow triangle in the middle, which is recovery mode but it will not run the update.
Ashok Dharshan
