Tripod quest for plus size phone and .... With protective case!
clhjr
14
7
3
OK Admin. Feel free to place this anywhere you think will help with exposure. I need a tripod for a Samsung Galaxy s25PLUS.
I ordered a recommended FugeTek tripod which is fine, but the phone holder accessory will not hold the Galaxy s25PLUS with a protective case around it.
It probably would fit (snugly) without the protective case, but I am not going to remove the case.
So, I need to be introduced to the larger world of smartphone tripods and accessories.
Has anyone been on the same quest? What did you find? Appreciate any help.
Also the phone holder they sent me did not have any of the soft edges to hold the phone. It was just hard plastic.
Thanks,
Reactions: BEaRebel
You were in the Samsung forums just the older ones I moved it to the s25 series forums
Thanks,
If you have a magnetic case, I recommend this one. It is very compact, but opens to about 6 feet tall. It has an included Bluetooth shutter remote (since we lost Bluetooth on the Spen). It's not super stable for windy conditions though.
Vimitty for MagSafe Tripod for... https://www.amazon.com/dp/B0CSJQ1JQT?ref=ppx_pop_mob_ap_share
Reactions: mustang7757
Thanks for the replies. Looks like that would support it. Just get a new case with the magnetic connection and go with that. Seems like the number one suggestion right now. I was hoping to find a 4 legged tripod (yes, that is an oxymoronic statement or something) but this is best suggestion so far.
Thanks.
Thanks again.
TheGreatApe00
