Try the Targus case-works well for Flyer with pen holder
DaveGPhx
8
3
I found a suitable leather folio case for the Flyer and it works quite well and it even has a pen holder inside the case for the "magic pen." I found it at Staples and it was designed for the BB playbook; however, the flyer fits perfectly inside of it and it does not distract from the magic pen icon either in portrait or landscape mode. Targus makes this case and I found it at the BB playbook display case. The off/on button is easily accessible and the volume controls are only partially covered (just a bit on the top volume but still can press it to control volume). Another added plus is that is has a built in stand with three positions so that you can view for movies/videos. It is leather and it is sturdy. It is a bit bulkier than the rocketfish case but it is sturdier and feels great and the Flyer is very protected. Of course, it does not have a camera opening; however, I would imagine a hole punch would work fine or you can take it out of the case easily to snap photos if you so desired!
I have been very happy with it. It has a pen holder! Some pictures are attached...definitely worth checking out.
Oh... Sorry I forgot to mention that part! The front camera is completely unobstructed! Great case.
It does not cover up or affect the buttons in landscape. I have been using it for a week now without any issues.
It's buttugly closed but also is the best case I've seen that is comfortable to hold open,holds the pen and allows access to all the buttons. The m-case look executive leather case also holds the pen but is uncomfortable to hold open.
Sent from my HTC Flyer P512 using Tapatalk
Your right. I got one yesterday and so far it's working great. Love the different positions, works great on my lap.
Thanks for letting us know about them.
Reactions: Crispelb
What about the microphones? It looks like they may be covered with this case. Has anyone tried audio recording with this case? Thanks.
Thanks for the info. I got the RocketFish leather portfolio case, which is very nice, but way overpriced in my opinion. The RocketFish case has a nice, small form factor, but has no place to put the expensive pen. Have you compared the two cases?
Got Mine Yesterday
I got the Targus case also and it works fantastic. I rarely use the rear camera so far and can always take it out of the case if I do. But other than that the case is great - fits fine - i cut a piece of the foam that came with the case and slipped it into the bottom holding area to give it spring and a tighter fit when the Flyer is inserted and that has worked great!
I found this case on the BB for business website. Some of you may already know about it. It's an official HTC leather case with a place for the pen. I don't have it nor have I seen it in person. Just thought I would post it. It looks nice.
Best Buy For Business - Product Detail
No pen holder??!!
Stopped in at Staples where I live today. Saw two Blackberry Playbook cases, being sold for that device...must admit I didn't check to see if they were by Targus...but I assume they were. The models were the "convertible" and the "journal". Neither had a pen holder. I'm stumped.
Thanks for sharing the great information!
The point of my post wasn't very well made. I'm just saying that I went to Staples to find the case shown in DaveGPhx's post....but they didn't have it (no pen holder.) Has anyone found it at other, specific, retailers? Thanks in advance. The pen holder is the key for me.
Guessing more options for cases will be popping up on the web in short order. Would be good to keep this thread alive with any good additions.
Staples does carry them. If you go online and search for "targus" it will appear. It is a leather truss case. It sells for 44.99 and once you select it you can select the "check store availability" option and type in your zip code. It will show which ones have them in stock. I am in the Phoenix area and all of them show in stock. SKU is 092636260880. Good luck!
liquidsnake757
