trying to root my shift
dude im not complety a moron now i realize what happens when you extract files. and there is a shift older with those files in it and the are in the root of the SD card.
and in my shell im seeing the # i have root to my device
Dude...I didn't say you were complete moron, I have no idea what you have or have not done since your not really providing much info... If you don't want the help that's fine, cause that's all I'm trying to do is narrow down the problem and help you out...
Honestly this shouldn't be this difficult..
Reactions: CD82
no i want the help
so ive got my phone back to 2.2 trying to use this hboot
ive extracted the files from Shift-root there is a folder name Shift
in this folder there are two files named hboot_eng.nb0 and hboot_orig.bin
ok this folder is in the sd card of my device my device is connected to the pc
ive got root to the device im trying to check the md5sum of the files
its telling me this
# md5sum /sdcard/Shift/hboot_orig.nb0
md5sum /sdcard/Shift/hboot_orig.bin
md5sum: can't open '/sdcard/Shift/hboot_orig.bin': No such file or directory
That's strange if you have the files still inside the Shift folder..
Try this
Code:
Busybox md5sum /sdcard/Shift/hboot_orig.bin
Reactions: CD82
this is what i get after i run that cmd
# Busybox md5sum /sdcard/Shift/hboot_orig.bin
Busybox: not found
the files are even showing up on the phone when i go into the sd card
Busybox: not found
Edit: I misread your post
Get busy box and push to /system/bin or download busybox installer from the market
I would also suggest jumping in the Shift IRC, there other folks in there that can help.
http://webchat.freenode.net/?channels=HTC_EVO_Shift
busybox is kind of the swiss knife of a unix tool.
You can try busybox md5sum
Or maybe
/system/bin/busybox md5sum
type /system/bin/busybox md5sum in the cmd?
If you pushed busybox to system/bin or used busybox installer (there are 2 options with the installer /xbin or /bin) Try this
First try this command
Code:
Not sure if busybox is in caps or not but it is case sensitive so try both if the caps doesn't work.
Still no dice try this
Code:
/system/bin/busybox md5sum /sdcard/Shift/hboot_orig.bin
Crump i want to thank you alot for your help a big help. thanks a ton man now ill get to learnning some of this stuff thanks again.
for some reason though it wont let me connect to htc sence.
so having a shift thats rooted is it agensts sprints terms could i get an anser ASAP?? please
my battery in my phone died wont take charge n stuff. im gonna try to goahed an get a new phone im tired of this thing its so close to gettin my upgrade
im just wondering if there rooted phone is agensts tos for sprint
ameliadinkins
