Turbo Fast Via The Animations Scale Setting (one click speed enhancement)
hisense
233
Within Developer options (which you have but may be hidden)(rapidly press the Settings▶About Phone▶Build Number. Then exit one screen back and see it in the list) you can change the speed of animations. This means you can make things move visually faster.
Settings▶Developer Options▶Window Animation Scale .5x▶Transition Scale .5x, Animation duration.
Notice a UI speed increase now.
Just did this after reading your post. Definitely notice a difference immediately! Will this effect the battery life at all? And will it be for better or worse?
These are settings that are commonly set to .5 in custom ROMs to fool newbs into thinking the ROM is faster than stock. Not all need to do this but it is a common practice.
These sre settings that are commonly set to .5 in custom ROMs and fool newbs into thinking the ROM is faster than stock. Not all need to do this but it is a common practice.
I know and I cannot stand when the developer claims the rom is faster and when I look the animation scale is changed.
I keep mine set to off. I've got no need for animation. Doesn't do anything other than look pretty.
jades
