Two Chrome broswers
Thread cleaned up -- we don't allow discussion of apps intended to bypass paywalls.
No problem -- we know you're not one of those shady types who really push this stuff.:)
Thank you!
I really do try to help folks, here!
I'm thankful for all of the help, I have received, over the years!
This is an invaluable resource!
I also had the same issue but it got resolved, follow the below steps :
Go to file manager and search for the folder " com.android.chrome", if you are able to find the folder delete the folder and restart your phone then the other chrome app will disappear from your app drawer
I faced the same problem recently. The dual version of the chrome app popped out of nowhere. I cleared all data, of both the original and the dual app and uninstalled updates. Then after rebooting the phone, it was gone. If you want to keep your history and bookmarks, make sure its synced with your google account before deleting the data.
So I've been having the same issues with dual Chrome and android system view apps. My solution was I went to settings-Advanced Features-Dual Messanger. After clicking on dual messenger there should be 3 dots in the top right corner. Click them and then select Delete all my data. That worked like a charm for me.
Reactions: J Dubbs
kctraci1
