Two Optimus Vs With Same Bluetooth Address? Using CM7 ports
No, this was never fixed last time Schlidel brought it up. I've been trying the last couple weeks to solve this on my phone and have yet to find a solution.
I made a lengthy post in the IHO thread yesterday about it, including some things I have tried. See here.
Maybe it's better to keep it in a separate thread. Either way is fine with me.
Just for future reference: This issue of duplicate Bluetooth addresses was discussed further in the IHO thread. Mrg666 tracked it down and wrote a patch which can be found in this post.
Read the posts before and after for context and to understand what the patch does.
Future IHO builds should have the patch built in.
Thank mrg666!
Reactions: Schlidel
Thank you I was meaning to do this.
Reactions: Dannemand
I have that patch on my Box account lemme see if I can find it.
Boom. https://www.box.com/shared/223257f013266f2f5074
Let me know if that link works for you. I'm fairly confident that's the final revision of mrg666's fix. ;)
I'd also like to note that mrg666's later/latest roms incorporate this fix.
Sent from my mirage'd OV.
Reactions: mrg666
Let me know if that link works for you. I'm fairly confident that's the final revision of mrg666's fix ;)
Thanks! Yes, it is the final revision. I think I deleted the file when I was cleaning up the mediafire folder. Will you keep this file available or should I upload it again?
Thanks! Yes, it is the final revision. I think I deleted the file when I was cleaning up the mediafire folder. Will you keep this file available or should you upload it again?
I don't know how long box will keep that link alive and I don't have any file hosting accounts besides box/dropbox.
Have a place for it?
Yep, I have restored the file in mediafire and corrected the download link in IHO thread.
Reactions: Schlidel
I've had links posted from my box account for over a year and they're still active. I usually get between 20 and 35 hits a week.
Reactions: Schlidel
elijahchileshe12
