Tylt Vu Qi Charging Stand vs. Verizon Qi Charging Stand?
No, you are not missing anything, but the folks at Motorola sure did.
There is no docking state so daydream does not function properly. Daydream needs a "when connected to charger" state to work with the Qi charger.
I found this app - Dock Clock - run it in "Manual" mode - its free and you can change the color and brightness for night or day use.
Sean, I get the same behavior from my Verizon stand, though I use Dock Clock.
Not sure why, but my Nexus 7 works perfectly (same app, same charger).
What model Nexus 7 do you have? Do you have a case on it? If so, which case?
(I have a Nexus 7 2013 with a Poetic slim case, so I'm all ears...)
Looking at a Qi charger or two for my wife and I. Thinking the Tylt. But a quick, maybe dumb question:
I like to turn my phone off when charging (process has never failed me yet). Does the phone need to be powered on for the Qi charger to work, or can the phone be off?
The Phone can not be off. But let me clarify - I think its the Phone not the Tylt charger..
So if the phone is Turned off and placed on the power Qi Charger.. it turns on and starts charging.
If the phone is on the Tylt charger and is turned off it immediately turns on again.
I just tested this and the minute the charge hits it, it turns on.
It does the same thing with the Verizon charger. I wish it could charge with the phone off too.
I am currently on my 2nd Qi Charging Stand (VZW3COIL-WC).
I like the charger itself, especially the angle but according the included instructions once the phone has completed charging the red LED is supposed to turn off however my red light stays on as long as the phone is on the dock. The ONLY time I see the LED off (Standby Mode) is when the phone is not on the dock. Verizon is aware of this issue but they are not sure what the problem is but they are looking into it. Has anybody else had this issue? Know how to fix it? Thanks So Much in Advance.
Hey folks, not meaning to hijack, but a quick word: qi charging doesn't work if you have a case with metal on the back, such as a kickstand, that comes in-between the charging plate and the battery.
I just found this out in using my Tylt Vu with a case that has a metal kickstand; I discussed this in more detail in the cases thread, but thought I'd give a heads-up here.
Works fine on my Verizon Qi stand with Seidio case on the phone.
I have the Verizon one. It works fine. I chose it over the Tylt Vu because the Tylt Vu takes up so much space (I use it on my nightstand) and the Verizon one doesn't. The charging light is quite dim, no problem on a nightstand.
Thanks, I am just trying to figure out why the red light does not go out on the Verizon stand as the directions that came with it said the light should go out when the phone is charged.
The red light on my Verizon stand goes out when the phone is done charging.
I have the Verizon stand and the light goes out after it is finished charging.
Thinking about getting the Verizon branded wireless charger for my Turbo. Any negatives over using the corded Turbo turbo charger?
Sent with my Kindle Fire HDX 7" via Tapatalk.
gaganprasad
