Ultimate Battery List with Cases for Extended batteries(More Batteries to come)
rlatjs17
23
Just wanted to share this info with android central since im mostly on XDA. Just copied over my XDA review which can be found here
http://forum.xda-developers.com/showthread.php?t=1843896
Hyperion 4200mAH
http://www.amazon.com/Hyperion-Exte...ag=hawk-future-20&ascsubtag=UUacUvbUpU2190394
Hyperion 4200mAH Screen Times 7Hrs 38Min NFC Capable (pictures Included)
Can not use original battery cover
Battery Drain(GPS, 100% screen brightness, Bluetooth, Cpu-Load)
4G was on the whole time
Hyperion Charge Times 4Hrs 47Min
Price $16.99+Shipping on Amazon +90 Day warranty
Anker 4400mAH
http://www.amazon.com/Anker-Extende...ag=hawk-future-20&ascsubtag=UUacUvbUpU2190394
Anker 4400mAH Screen Times 6Hrs 7Min No NFC
Price $9.99+Shipping on Amazon+1 Year warranty
QCell 4200mAH
http://www.amazon.com/QCell-Extende...ag=hawk-future-20&ascsubtag=UUacUvbUpU2190394
QCell 4200mAH Screen Times 5Hrs 27Min NFC Capable (pictures included)
QCell Charge time from 0%-100% 4Hrs 34Min
Price $21.99+Shipping on Amazon
Hyperion 2200mAH
http://www.amazon.com/Hyperion-Comp...ag=hawk-future-20&ascsubtag=UUacUvbUpU2190394
Hyperion 2200mAH Screen Times 3Hrs 21Min NFC Capable (pictures Included)
Fits in original battery cover
Price $9.99+Shipping on Amazon +90 Day warranty
QCell 2100mAH
http://www.amazon.com/QCell-Compati...ag=hawk-future-20&ascsubtag=UUacUvbUpU2190394
QCell 2100mAH Screen Times 3Hrs 7Min NFC Capable
OEM 2100mAH
http://www.amazon.com/Samsung-EB-L1...ag=hawk-future-20&ascsubtag=UUacUvbUpU2190394
OEM 2100 mAH Screen Times 3 Hrs 7Min NFC Capable (picture included)
OEM Charge time from 0%-100% 3Hrs 12Min
Price $24.68+Shipping on Amazon
CASES For Larger Extended batteries
Seidio battery covers fit the Hyperion 4200, Anker 4400, QCell 4200
$14.99+Shipping for the Battery cover from Seidio
Hyperion honeycomb case and the Qcell case fit Hyperion, Anker, QCell extended battery covers but do not Fit Seidio Battery Covers.
Update
Best Protection for Extended Batteries(You will need the Seidio Battery Cover)
$34.95+Shipping
Might cost you a pretty penny.
http://www.seidioonline.com/samsung-...ssgs3xk-bk.htm
Seidio Case(Will only fit with Seidio battery cover)
$29.95+Shipping
You can order just the battery cover without the battery by calling customer service. $14.99+Shipping from my understanding 1-832-204-1118
https://www.seidioonline.com/Product...e=CSR5SSGS3-BK
Seidio Case with Holster
Will update once I test the protection and other little things.
https://www.seidioonline.com/Product...D2-HR5SSGS3-BK
QCell
Better protection than the Hyperion but only 2 color options. But, full coverage screen protectors will get lift with this case. It'll provide better protection from drops than the Hyperion.
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU2190394
Hyperion Honey Comb
Has the most color options but the volume and power buttons are very hard to push. I wouldn't recommend it for protection either, since its very very very thin.
Re: Battery Thread
Cheap, thin, slippery. Not worth the money. The seidio back covers and cases fit on the Hyperion 4200, Anker 4400, and QCell 4200. If you want to buy just the back cover without the battery from seidio you have to call customer service and order it.
Re: Battery Thread
I don't think I will be a power user. I am going to by a couple of batteries and see what that gets me. I read your posts on the other side and feel you are an expert. Can you trust the batteries on eBay? Some of the sellers do have good reviews. How high can I go in a regular size battery. Some go as high as 2900. I was thinking of getting 2-3 of these, but I don't want to screw this up. Should I stick the names above and Samsung brands or just skip eBay and go Amazon, or Andriod Central.
Re: Battery Thread
Do not buy anything over 2500mAH that says the battery is the same size. It is impossible to fit all the cells inside the battery and keep the original size. Even the 2500mAH batteries are "iffy". There have been some threads showing underneath the sticker the supposed "2900mAH" batteries are in fact 2100mAH or 1450mAH just relabeled as 2900. The largest original sized battery I would trust is 2400mAH and even thats pushing it. I would only buy a tested branded battery with a size higher than 2100mAH. You might get lucky with the 2500mAH batteries on eBay though. One more thing, DO NOT BUY THE GOLD BATTERIES. I tested them and they are weaker than the OEM batteries.
Re: Battery Thread
Thank you for the help. Is there a double sided battery charger out there? I want a charger that has spots for 2 batteries that charge simultaneously.
Re: Battery Thread
I've said this before but, I don't understand why they don't make an extended battery where the battery and battery cover are all one piece and all part of the battery. That way you could actually make a bigger mah battery and keep the slim profile of the phone.
Re: Battery Thread
Anybody know of a decent case that would work with the Mugen Power 4600mAh Extended Battery?
