unavailable functions
Depends what functions? If they are basic AOSP (pure android) functions they should be fine, I doubt any HTC specific stuff will work though
My M8 posted this
also could someone please give me a link on how to get access to xda + will I loose any original HTC software installed if I root and unblock it
As I said, look on XDA, maybe by searching using your SOC code to find any ROMs available. I don't think your phone would be hard to root at all
My M8 posted this
thanks a load mate for all your time an concern and a big thank you to all others buddies who help me figure this out. Thank You
Can you boot into the bootloader and in fastboot mode and with a cmd prompt type this and post it "fastboot oem getvar all"
Fastboot is Not in Settings, you power off and then Hold Power and Volume Down until a white screen appears, The option for fast boot is there, Using your up or down volume to navigate select fastboot, then plug in your device
To enable or disable fastboot is in settings. He doesn't have it because he has a knock off chinese model M8
ElectraDriver
