unfortunately, Google Play Store has stopped
Ok let me help yu with what i did with my samsing galaxy grand i9082. when i installed this custom rom of lollipop 5.0 i got several popups saying google services has stopped and ****.
here is what i actually did !
The prob wasnt with my custom rom but it was with the GAPPS File i.e google apps file which i flashed at the beggining. it was an outdated one. that is the reason i had those popup's.
Open the below link and see the decription for Samsung s3 gapps file and you are ready to go :)
Hope this one helps yu ! God bless.
Bizarre: I just got a HTC Desire 520 with Cricket Wireless, which runs Lollipop 5.1. As soon as I type the letters "droi" into the search field in Google Play Store, I get the "Unfortunately, Google Play Store has stopped" message and the Play Store app crashes. Otherwise, it works normally.
Default
I have samsung Galaxy tab 2 10.1
There is an error occurred
Unfortunately Google Play Store has stopped this error appeared my tab pls help me out I'm tired now .
Hiya, I have a Sony xperia z5 and every time I go to purchase something on Google play store whether it's an in app purchase on a game or within Google play itself it anyways comes up with the message ' unfortunately Google play store had stopped and won't let me continue with the purchase, I've tried restarting the phone and doing the force stop thing but nothing seems to be working, can anybody help?
It's fine now I figured it out! All I did was uninstalled the updates!!
Re: unfortunately, Google Play Store has stopped
What happens if you try to uninstall the play store app? If you've installed updates, it should allow you to remove the updates and go back to the stock version. See if that works.
Do other google apps, like gmail and google maps, work correctly?
This worked for me!! after trying to clear caches force stop and God only knows what else I did to my poor phone. I didnt even notice when it did update last but ive been having this problem for a little while. Thank you soo much meyerweb!!
Hi... I use tab vandroid tx 1 plus, In this week. got the same problem when I install app from google play store, it always say unfortunately, google store has stoped. Already try all solution already you mention several times (clear chache and data google store, clear cache google play, force to stoped the application, reinstall the applicatiion, remove google account and restart the device)....including reset to factory setting... but it doesnt work for me.....Please help me find the solution or share the solution ...thank you
I have samsung Galaxy S3
Unfortunately Google Play Store has stopped this error appeared between 2 seconds on and on and my mobile goes very much slow. I switched enabled in downloads .pls help me out I'm tired now:'(
nida plz your mobile hardreset
I have an HP Slate 17 model 1020, Android 4.4.4
I was getting multiple "unfortunately .......... has stopped" errors. My device became unusable.
I followed all the clear cache / data rec's. I did the factory reset several times, which initially worked but within minutes, the errors resurfaced. After several attempts at doing the same thing and hoping for a different result, ;), I noticed updates downloading and decided to disable auto update in the Google play store, which I had to do from another device but the same Google account.
Factory reset and ........... Stable!! No errors! Disabled all manufacturer software (sorry HP but need my yablet), games, Hangouts and Skype. Carefully updated, one at a time then reboot, Google system and integrated apps, YouTube was last. Still stable.
Tried YouTube, streamed some video and STABLE! YEAH!
NOW FOR Netflix. Nope, errors from play services and store. Uninstall, reboot and stable again.
I did this for any other video streaming app that I used and they all failed except Crackle, which would open, search, play one movie and then crash my system. Reboot and ok until my next Crackle fix.
For over a month now, it remains stable. I haven't installed anything else and keep play auto update off. This affects all devices on that play account (except for my phone, don't know why) but my devices never slow down because of an unexpected update download. In fact, they all seem to work better than ever.
This indicates that the issue is with the streaming apps and not Android. I suspect they have updated their apps code, optimized for newer android versions and don't support legacy versions. Understandable, given the thin resources for such work.
Hopefully, this helps someone. This advice is free and I want it to remain that way. /FyreQ
amateur_user
