"Unfortunately Samsung keyboard has stopped working"....
Thank you very much for this info; Ive tried this on my note4 and the keyboard error message has disappeared!!
Thanks again!
Leo
cache removing not working in my phone. plzz tell other solution. it is frequently saying keyboard stopped.
Mine does this as well. I had tmobile back up and factory reset my device. Didn't resolve. So they sent me a replacement device saying it was hardware malfunction. Got my new device yesterday and it was working great but it's doing all the same things again.
Galaxy note 4 here.
This must be a software issue. Whether it's android or Samsung I have no idea. It didn't start until the recent lollipop update on my previous device. I think they need to look more into this though it's quite repetitive and obnoxious.
Hi, i had the same problem with my keyboard not letting me enter any txt, i did what you suggest, going in settings, application manager...i found samsung keyboard and did clear data and it worked again, thanks a lot.:D
I did as suggested and cleared the cache and is back to normal. Gracias !!
Try this: Go to Settings / Application manager. Scroll right to the "All" tab. Scroll down until you find Samsung keyboard, and tap on that row. Than tap on Clear Data. Let us know what happens.
Try that already and had no luck any other ideas
Nothing still has message error popping up
I just wanted to say this does work. My phone keyboard was doing this and after i did these tips. the keyboard worked again! :) So thank you!
three concerns in my mobile s3 neo
1) Unfortunately Samsung keyboard has stopped
2) Unfortunately Samsung text to speech engine has stopped
3)Unfortunately TouchWiz Home has stopped.
Please help me regarding this
Dear All,
I was very much worried regarding disappearance of default Samsung Keyboard. I followed your steps and got 100% results.
I am again very grateful for your guidance.
Thanking you.
Muhammad Aamir
Pakistan
[phone number redacted by Mod]
Help my Samsung J1 won't let me type at all since i made this Minecraft world which had a massive file it just stopped i deleted the file turned my phone off and it won't work!
reboot the phn then clear ceach then power down,full syestem is starting like a new phn.then update all files.its work.
MisterVoltio
