Unknown Error code during application install: "-24" Help?
The same is true here on my Galaxy Nexus with version 4.2.1 Seems to only affect the paid versions but especially annoying because can't get it upgraded and the loss of Titanium Backup Pro disabled. The Battery Widget guy said it was probably due to a corrupted data on the phone itself.
I have a good file manager but cannot find the data/data folder. I only have data folder and inside that is com.keramidas.TitaniumBackup. I figure if I delete that, I loose all mybackup?
Installing the Rom Toolbox allowed me to see the data/data folder with the deviant codes that didn't allow me to re-install the program with out the error-24. Thanks for the info!
re: Unknown Error code during application install: "-24" Help?
I had this problem trying to reinstall minecraft pe. Could anyone help?:'(
You have to have root access to view the data/data folder and also mount your root as writeabel. Don't forget to remount your root as read only when done. I suggest Es filebrowser for this. The root settings is under the settings menu (...).
I also just flashed a Jelly Bean ROM, and everything seemed to be working fine, except when I tried to restore Pure Calendar Widget from Titanium Backup, it froze. I figured I'd try to install it from the market, then bam, that's when I got the unknown error -24. It was only with that one app, and everything else works fine :-\
Unknown errore -24 plz helppp
Same problem for skype
having this problem with Facebook too, i uninstalled it and when I'm tried to reinstall it it wont let me, first i offed my phone, did not work, i tried doing the /data/data/ thingy but cant find, i downloaded file managers but still cant, i downloaded titanium but i says that it will not work on my phone, i wanna try rooting it but its too complicated for me, now I've decided to back it up via kiss and will try to do factory resets, i hope it works, is there any other way encase this thing will fail? my phone is Samsung galaxy note, 4.1.2, i didnt have any problems before, only now when i updated it that it slowed down and all this errors keep appearing...i just can't lose my Facebook of all the apps!!!!!:(
yey! fixed it!!
Omg I'm having this same probably could you.I help me and tell me how did you fix the probably if you have kik kik imherboobie_ or text me 4782075781 Thanks
Thanks for this thread, it helped me reinstall my "Craigslist App"! I appreciate the instructions! :)
I have the same error with downloading Minecraft Pocket Edition 0.7.0
Where would i find the data/data for the application? I'm having this issue trying to install the Facebook app.
I had a -24 error with Skype. The solution I've googled on lifehacker.com is very simple and works for me. Settings -> Apps -> Google Play Store -> Clear Data. Just wondering if it can help you too.
Clearing the Google Play cache and clearing the data did not work for me. I still get the -24 error when trying to re install Facebook. Short of a "Hard Reset" is there anything else one can try??
Thank you
:confused:
Are you rooted?
Do you mean 0.6.0?
so im trying to install the new google keyboard app... but i get the error 24 message as well. Cleared cache and data on play store, services framework, and downloads. galaxy s4 not rooted. other apps install fine. what do i do?
im having this same error with facebook for my completely stock, unrooted GS3
how did you fix it?
deleting data/data/"app folder name " solve the problem ..
Thank you ...
Some one help me on how to get rid of this.. ive deletedbit tried to reinstall it.. snapchats not installing. Help? (Im not factory resetting my phone)
Where do i find this i have a samsung galaxy s2
Yhea but if I do a factory reset I will lose everything
True I will probably fix the problem but I will have
to reinstall everything else and I will lose all of my
photos
I have a problem downloading Skype. I went into the data/data thing and there wasn't one for skype. I'm so confused.
lilyo7788
