- Nov 25, 2010
- 15,958
- 2,752
- 0
Do you think it is unreasonable to expect Wug's toolkit to give you a warning that your device will be wiped before it wipes you device?
No I think if it wasn't mentioned that was a slip on the devs part.
Although it is also common knowledge that most devices with a boot loader that requires to be unlocked also means you wipe the device. Most cases if users do all the proper researching and required reading before attempting Rooting & Hacking they come to realize that this is common (most cases) during the unlock or process of placing a custom recovery on the device it also means you wipe the device.
It's unfortunate that it happened but we see it all the time and in the end it's the fault of the user for not reading enough, asking questions or simply backing up stuff just in case.
Before I became a Moderator and was an Advisor here at AC, I always preached time and time again in my guides and posts...
"if your ever unsure of something regarding rooting & hacking, stop...ask.. and wait for an answer before moving forward." This time it only cost you some pictures, your lucky compared to many that end up with bricks
Sent from my Nexus S 4G using Android Central Forums
