Unlocked SM-G920V - unclear-able notification SIM card is not from Verizon Wireless How can I fix this?
Amin Suleman
5
Unlocked SM-G920V - unclear-able notification "SIM card is not from Verizon Wireless"
Hello All... I need your help!
Loving my new S6... she's sweet! BUT, i cant dismiss the notification of "SIM card is not from Verizon Wireless". The phone works perfectly fine and is unlocked and I'm using a Digicel Sim (Caribbean Carrier) but i cant get rid of the notification.
Any thoughts or insight appreciated. I have attached some screenshots
Re: Unlocked SM-G920V - unclear-able notification "SIM card is not from Verizon Wireless"
I think you need to be rooted to get that notification away.
Yeah you need root, which is available for it.
Sent from my Pearly White Verizon Samsung Galaxy S6 Edge
If you use android Lollipop here is the way to do it.
Go to settings >> applications >> application manager >> all
Then find an application called "activation agent".
Click on it, then click force stop.
:D
Thanks, that worked, Now only issue is sending mms, I have galaxy SM-G920V, thanks in advance !!!
:D
i think that only works until next rebate. disable is grayed out. only can force stop.
Force stop "Activation Agent" like said above, for MMS to work Google your carriers APN and follow EXACTLY.
Chloe7788
