Unread message notification
I tried this trick too and it worked after my s3 started showing phantom tx mssd notifications :) go to applications manager then ALL APPS then BADGE PROVIDER and clear data then restart handset..worked 1st time:)
some quick googling revealed some GS3 owners with similar complaints.
Above was the suggestion. I have no idea if it works or if it is safe to do. Perhaps useful... ? I don't know.
Totally worked for me and my GNote2 has been like this for months, I just learned to live with it after trying to do so many things to fix it. YOU ARE THE BEST!!!!!!
This is the only way and the correct solution. Step 1 for the resolution for this kind of problem is the reply given .:)
UGH! It didn't work for me or my son. We both have Gnote2's my problem is in the email notification drop down window. It says I have 9 unread messages.
It occurred when I accidentally deleted a couple emails and went to my trash folder and copied them back. I have sence tried:
marking everything in every email account as unread, then again read
cleared the phone's cache
the email cache
tried the badge provider's trick and rebooted.
I've done a battery pull.
Went into Android assistant and tried it all there. Nothing works.
Any clues?
And when we figure THAT one out, my son's phone shows a negative 1 as in (-1) on his email desktop icon. (I suggested he needed to write home more often, he was not amused.)
Great news this worked. I had same problem. I had 3 apparant messages now cleared brill. This was annoying.
Well done thanx for sharing! :cool:
Thanks a million times !! i was THAT close to break the ******* thing on the wall !! it was driving me insane that NEW message icon !!
Thanks again !!
Hi,
I have broought a new Galaxy Grand last week and facing the same problem of message unread notification inspite of no new messages..
Please help...
Guys i have a problem with my galaxy s 3
The messaging icon shows 1 unread message but i don't have any unread messages!
Please help me :-*
focuspc
