Unread message notification
thanks a trillion..........worked perfectly for my SGG Duos & solved both my unread messages & missed calls problem :)
This was driving me nuts lately on my S4. Not sure why it happens but I got rid of the erroneous unread icon notification, until the next time it happens. I sorted by read/unread and deleted the unread. I know for sure that one of the offenders had in fact been read and deleted on my computer many hours ago. I tried many synchs in the meantime to try to get rid of it.
But it doesn't work for my mommy's phone. That's Galaxy Gio. I've cleared the data and restarted the phone but I still have that damned message! Help please! Mommy is going to kill me LoL
Help please!
It just goes OK by selecting select all messages and delete 'em. It seems that the message was hidden ans by deleting all messages , it would be OK
This also works for Galaxy S2 phones too! I registered specifically to thank all who contributed to this thread. I'm about to upgrade my phone, but my OCD was going into overdrive because that BadgeProvider was telling me I had unread emails.
Thanks!
The Beer Genius
I have an LG Lucid and I don't see where that application is. Do I need a rooted phone to fix this?
hello.. my samsung tab 7.7 still showing unread message .. same like before I clear data on badge..... did has anothe way to solve this problem... I'm getting crazy nowww
You need to reboot after clearing the data on the badge app... I had the same problem on my tab 10.7. Found this thread and it works. Try to reboot yours
My samsung S3 still have the problem even after it got updated to 4.3
New message notification is still appearing, after reboot its resolved but after each message iam getting this issue
Go to Settings > Application Manager > All applications (on the top). Locate the "BadgeProvider" app, once in there select "clear data" and reboot
Still not working.... can any one help me plzzzzzzzzzz:'(
I'm using Missed It and after 4.3 it won't clear out the widget or the badge. The clear data and reboot works only until I get a new notification. Pretty annoying but I think I can chalk it up to the 4.3 upgrade.
Turns out it seems to be just for MailDroid. It works just fine on the stock email.
Has anyone that can't get it cleared by following the instructions, called their service provider? I was having a problem with the new voicemail icon not going away, twice. Both times I called AT&T and they did a reset there that got rid of the icon for me in just a couple of seconds.
I learned that in this update, its still (maybe or maybe not) annoying that the notification for WiFi keeps coming in the notification bar, even though after you clear it, eventually, later on it will come back.. So annoying.. Anyone have this problem?
Sent from my SCH-I605 using AC Forums mobile app
some quick googling revealed some GS3 owners with similar complaints.
Above was the suggestion. I have no idea if it works or if it is safe to do. Perhaps useful... ? I don't know.
It worked for for me on Samsung Note N7000, thanx a lot
it does not only work for samsung, but also to all smartphone. my phone is himax,,,made in Indonesia...thanks for the help...nice thread.....and now i am using kitkat as my os... my prior os was jelly bean..
Hello, I have the opposite problem, and can't find an answer anywhere, I just started using messenger plus and made it my default, force stopped, and deleted the factory messg. but now I DON'T get the number notification over the app on my home screen and I need it. any help? This is on my droid.
The unread badge function only works on the stock Messaging and Email apps on Motorola devices. To work around this you will need to use a different launcher.
knightrider85
