Unroot and relock my nexus
So I download that app from the link you sent me and use the stock recovery.img?
After stock recovery is enabled I try odin again... correct?
Yep...that's what I'd try.
Edit, and yes.
Modem: Radios which you must flash normally if you want others (non-leaked).
Cache: No problem.
Normal for those to be missing.
Forgot to say that.
Gotcha. Since the phone doesn't charge I have to charge the battery in my new phone. I will give this a try in a few hours. Thanks again!
Okay, I changed the recovery image successfully I guess, and I ran Mobile Odin again, but Cyanogen Mod started up again. What am I doing wrong? lol
Also, I selected to wipe dalvik cache, should I? (In mobile ODIN)
EDIT
Crap. I just turned off my phone, and it's been stuck at Google for like 10 minutes.
EDIT 2:
IT TURNED ON. lol. Turned on into CM9 still but, as long as it still works.
What does that mean? Sorry, I'm still not good with the jargon.
Turn your device off. Hold down volume up, volume down, and power simultaneously until it vibrates. What happens?
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
It take me to an open Android with a start button. I can cycle between power, restart bootloader, recovery mode, and power off.
Brilliant. And your goal is to go back to stock, correct?
EDIT: NM, I forgot your USB is busted, ignore me. My apologies :(
Yes, back to stock. Apparently Mobile Odin will help me do that with the tar image I have, but so far, I'm not able to get it to work.
As a note: when I go into recovery mode, it takes me to the Google Logo. Been stuck there for about 10 minutes.
Am I running Mobile ODIN wrong?
All I do is load the tar and hit flash. Am I supposed to do something when the phone is starting up?
EDIT: Should I extract the tar?
Also, when I use mobile odin, and click flash, it restarts and does something really quick, then the phone starts up into cm9 and goes "Android is upgradeing your apps"
Two things I can do I think:
1. I bought mobile odin, you think maybe I should try the free version?
2. Flash some kind of stock on it. I just don't want the CM9 logo to appear on bootup. I think they'll definitely charge me if they see it.
Okay, I think I understand all of the "jargon" now.
I have all of this:
Radio: CWM-flashable
Bootlaoder: CWM-flashable
Recovery
ROM: Stock
Which do I flash first and in which order do I go in?
You know... in fastboot you start with the bootloader then the radio then the ROM...
However I think you should try in the order recommended in the xda post
Did you insert the system.img into the zip file on xda?
EDIT: Wait isn't that post for the GSM Nexus?
Do not flash any GSM nexus files they will hurt!
I only read the instructions. I noticed it was GSM.
Also, if I flash a new recovery before rom... won't that disable me from flashing a new rom?
noroldie
