Update difficulty
Bombing this thread with my update difficulty. The window that allows you to see what you type in a message using the twitter app or the google voice app disappears so I can't see what I am typing.help.
relentlessplayer..using the mighty SGH-T889
I Love RC helos and airplanes. Did you notice they offer a split screen in text. How do you turn it off. Or is there only 1 setting for text and email
Did you notiice what we discussed yesterday? Clearly after the update battery times changed. I have no figures, but its enough for me to notice it and think something is different. Several others have said the same.
Looks like you fly a T-Rex 700 and you have a DX7 radio...... :cool:
Nope,
That is my rave 450 and I use a 14MZ. I also have two N9's, a 50cc aeroworks ultimate bipe, a funtana 125, a few foamies and a micro heli that I hover, fly backwards and pirouette around the living room. :D
Yes, the split I have observed is in landscape. I have it turned off in the email settings. Either that or the general keyboard settings. I sometimes forget which. There are so many settings that my old brain fails me at points. I don't care for the split when just using one application.
And unfortunately, I can't speak on the update since I am rooted in this one and my international of course is running more like the rooted setup. So either scenerio, I haven't done the att update.
Man, I mentioned to you when you were having the email issue that I would do a factory reset. Something just doesn't sound right and is much faster and easier to do that, than to chase a needle in a hay stack.
Not sure to be honest, haven't run into that at all?
And I had a700 when they first came out and had tail gearbox issues, so i sold it. I was using a 9303 at the time. I had a dx7 when I first got back into the hobby like 5 years ago. I have gone through a fleet of 600's and just like the synergy build quality and rugged nature. The same with the Youngblood models (the rave in the picture).
They both are/were just more expensive machines. But I'm well past the crashing stage unless something mechanical goes wrong. Which isn't too often.
Sent using Note II
tuovst
