[UPDATED 12/30/2012][Sprint Only]UnRoot and Return to stock
Re: UnRoot and Return to stock
Your directions say for desk top Odin move cwm file to your desktop and then find the cwm tar file through Odin.am I putting the cwm epic team win file on the desktop? Cause it's not a tar file.
What your doing is flashing cwm tar file in Mobile Odin. It will reboot you to cwm recovery. Then while in recovery, flash team epic root from recovery.
_______________
Just Flash It !!!
I'm good now why does it go back to stock recovery after one unroots anyway? But yeh, I'm good to go now thank you!
Just samsung trying to make it harder for us. It wasn't like this with LEN. Samsung implemented it with (I think) lf9. If you aren't rooted correctly the phone will try to replace your recovery with stock. This is why you must either pull your battery or tell Odin not to re start when rooting. Also why I recommend using the no flash count method to root. It has superuser built into the stock image. The issue is the su it has is older. I will need to update the instructions so this doesn't continue to be an issue. Which I will do when I get off work.
_______________
Just Flash It !!!
I'm sorry to have bothered you do much.oh and I used chain fire app" triangle away" toreset my counter anyway.thanx again.
mine failed is it because i have an epic 4g touch... what happens if it fails and its still on the android picture on my phone...what is the next step
Please don't tell me you tried to root using the Galaxy S3 method. Please tell me you're kidding... If not, i would suggest you you head over to the touch forums and ask for help.
Hey thanks alot . I used this method and worked perfectly . I recive all updates just in half hour after going back to stock . N also didnt loose any data or anything . Thanks again
Hey Skunk! Are there mirrors for this file? I'm having a hard time trying to download it
Which file? And I will get something up for you. There's a bunch of them in this thread :D
But it will probably be after work before I can get to it.
_______________
Just Flash It !!!
Reactions: hiero
_______________
Just Flash It !!!
HA! What a dope I am, yes, sorry, I meant the KIES_HOME_L710VPALEN_L710SPRALEN_618049_REV03_user _low_ship.tar.md5 file
Unless you can just swipe off framework-res.apk for me
My link is working fine for me...?
Try This One
cool, that seems to be working a bit faster this time. Thanks! I decided to just start all the way back to my original stock nandroid image and go from there (I backed up a bunch of stuff with Ti Back). A good clean start wouldn't be a bad idea I'm thinking and hopefully this works.
If not, I'll go back to where I was and then flash this file and go from there!
Thanks SA!
Oh well, looks like I'm having a dev/block/mmcblkp01 error problem and it won't let me update. I guess I'm going to have to wait for this file to download and try again.
*edit* Thanks yet again Skunk!! This worked like a charm and I'm all up to date to lg8 now and just about to install cwm back on and root from recovery ;)
Thanksssss!!!
Will the phone start getting the stock OTA updates as soon as the stock ROM is re-installed?
jipeve
