[UPDATED 12/30/2012][Sprint Only]UnRoot and Return to stock
Re: UnRoot and Return to stock
Going back to stock right now to check if everything is good to go...
Why did you go back to stock just to check?
Pretty much... I have used the file many times and knew the process worked. But wanted to be sure nothing got borked when the file was rezipped. Since you have bricked one so far I just wanted to be double sure for you.
________________
Just Flash It !!!
I can't understand how some people think this is difficult. I have already went to stock unrooted. rerooted with custom recovery and reflashed my favorite backup and my phone is back in the identical state it was just 30 minutes ago. IMO This phone is about as easy as it gets.
In your directions out says double click on the Odin file, you mean right click? And above the steps it says make a folder on my desk top and name it root gs3.then in the steps it says to put Odin in the file named unroot gs3, is this the same one I created on many desk top
Double click to open the zip file the move the unziped folder to the unroot folder. Then you will double click on the odin folder and right click on the odin exe file and choose run as administrator. Since you already have odin unzipped. you will just have to open the odin folder and right clicl on the file and choose to open it as administrator.
There is a preparing your computer section and a using odin section. you would start at the using odin section since it is already installed.
Yes the same folder that you made on the desktop.
I just wanted to ask, has anyone tried this and had any problems?
_______________
Just Flash It !!!
i did this without a problem. after i followed the steps above and my phone has restarted, i got 2 OTA updates, so now im back at lg2.
What do you mean LG2? This kids for the sprint galaxy s3(three).
He is talking about the software and baseband version. The newest ota updated our software to LG8. He didn't like the update. So he went back to the original software version (LEN) and let it update up to LG8. It is a roundabout way to remove an update that you don't like.
Ohh! In sorry, just came from two and half years of rooted HTC devices.this actually means in a noob again Hugh?
That's awesome, wow its way harder to go backwards with HTC and the boot loader"hboot versions"!
Also how/where do I find the firmware emergencyrecovery code for the sph-l710?
Flykxd133
