USB connection issues on my Galaxy Tab A 10.1.
I just purchase a new Samsung Galaxy Tab A 10.1". I believe the tablet itself is fine as I was able to get it going and download the Apps that I want to use. It's main purpose is to be used as a digital dashboard for a project vehicle that I have running on Megasquirt. There are two Apps that will do this for me, Shadow Dash and MS Droid. Both are Android based. They communicate with the engine controller either by direct USB cable, Serial/USB adapter or Bluetooth. Megasquirt has both serial and USB outputs. I have tried both the direct USB and the serial/USB connections but neither one will establish connection with either App. Is there a setting someplace that I am missing?
Are you making sure that you are using like the original data cord that comes with your tablet?
Shawtiee
