Using biometric Logins
Dhawk1202
345
Coming from my Note 7 I loved being able to use my fingerprint to login to a bunch of sites instead of typing passwords. The v20 didn't seem to come with a personal Internet application, so I'm using Chrome. Does anyone know if this feature is possible?
That was a feature of the Samsung browser so not available on the V20. Not sure if there are any 3rd party browsers that do it.
While not the same, you may want to look into a password manager like Last Pass. It can auto fill in logins and forms, but I suggest this specifically because you can use the FPS to log into Last Pass. So it's a work around of sorts.
Yep, I second the recommendation for Last Pass. It's outstanding.
oh man, I love the Samsung browser on my S7 Edge and logging in with my fingerprint. I have a password app, Keeper Security, that allows you to use the fingerprint to access it, but that's not quite the same as the Samsung browser
Cool, I'll check it out.
Just a heads up, it's $12/yr. They do give you a free mobile trial and the desktop stuff is fully free, but it has a ton of other features that make it worth it and is probably one of the most secure cross platform managers out there. I used my Google Rewards credits to pay mine.
djdjjkzzz
