- Apr 19, 2010
- 52
- 18
- 0
On win7 64 bit. That's what I'm saying... Something isn't right. Has there ever been a time when flashing took forever?
Let me grab it real quick. Unless you have Yahoo? That I already have. Otherwise a quick GTalk DL won't kill me.
good luck tony....your in capable hands!! let us know how it turns out.
I'm having the same problem did you come to a solution? i need help!!
@ DroidXcon
I hope you can help me too.
As of yesterday i was fully stock, up to date with updates, but rooted. I have tried to install Clockworkmod (cwm-recovery-ALL.tar) using Odin - it failed. I downloaded the zip version, placed it on the SD card, renamed to update.zip and ran it from stock recovery option. It errored . Tried to reboot pnone connecting to a computer logo. Got back to the recovery menu- cleared flash and reset to stock - nothing helps. I still get no boot and icon with a phone and computer.
I was able to ran zadig - it recognized fascinate and I was able to install driver. I am still not getting recognition over USB.
I tried to Heimdall - downloaded atlas_v2.2.pit that allows to repartition phone - but I believe I am still missing some files that go with it - since OK button is greyed out.
Can you please give me a hand to recover from this soft brick?
@ Landshark
I have monkeyed with it for a hour and after multiple attempts - different sequences I was able to have odin push cwm and that fixed it my not beng able to boot issue/ being stuck on a "phone connected to computer" icon
I was able to boot into a initial setup wizard and later restore one of my old backups. Something that I have learned that aparently Samsung has two boot sequences on these phones and it might be a cintributing factor to a lot of soft brick issues out there.
@DroidXcon
I was a stock, rooted, no cwm and was trying to restore one of my backups - so I was in the process installing cwm. My mistake was that I could not find vs. 2.5..x and i tried Rom manager that supposedly ives you an option to install different cwm versions. Big mistake - somehow it corrupted my boot and i got a soft brick with no USB connectivity.
Using multiple attempts I was able to restore usb and hence re flash it with cwm - tat the only thing that worked since I could not push any rom, modem and even pit file.
An advise to all listeners - ROM MANAGER - an absolute garbage - avoid at any costs.
