Variable resitor(volume controller) hack for adding impedance to external mic circuit
califauna
5
Hi,
I'm trying to find a way to connect an external 3.5mm mic to my i9100 using a variable resistor (eg a volume controller in this case) to add impedance so that various mics with their different impedances can be connected freely, rather than just adding an inline resistor of arbitrary value.
A splitter like like could work perhaps:
https://forums.androidcentral.com/e...%2F3107203310...84.m1439.l2649&token=P6PN7SMS
I was just checking out this thread for a similar hack:
http://forum.xda-developers.com/show...2&referrerid=0
and it says that impedance needs to be added in line with the mic so that the device recognises the mic as a mic (has to be above 1000 Ohms).
This has me wondering if, instead of adding a resistor in the cable that goes to the mic jack (or in the cable of the mic itself), it would be possible to use the splitting adapter above and plug a volume controller like the one below into the mic jack of the splitting adapter then the mic to the other end, like this:
http://1drv.ms/1c7ZwLY
Using the volume controller I can change the resistance between the tip connections of that cable, from 0 up to 1250 ohms, and then it jumps to infinity.
In the above photo the adapter is designed for nokias (OMTP) so the TRRS pinout is different to the i9100 (CTIA).
If I get a CTIA TRRS adapter, will I be abe to make this work using the volume controller?
viaCern
