- Apr 26, 2010
- 41
- 0
- 0
Trying to figure out this answer, see if anyone knows....
Has anyone figured out on the Verizon Unlimited, you get 10 gb of hotspot ... If you add a device for the extra $20 for a Surface for example is that an extra 10 GB, or is that limited to the 10 GB that device gets. My issue is that I tether while at work and of right now 20 gb usuage I use probably 15gb in tether. So trying to figure out if the extra $20 a month gives me 20 gb total tether or just 10gb for that device then its not worth the change for me.
Thanks
Thanks
