Verizon Galaxy S3 Jelly Bean update questions
Well I'm sure that I'll end up doing it whenever it comes out. I was just trying to figure out the best/smoothest way to do it. Do you think I should do a factory reset? Or will it matter at all on a stock phone?
Do it after the update. Smoothes out a lot of issues IMO
Sent from my phablet.
Checked for the update this AM. Nothing so far.
Sent from my SCH-I535 using Android Central Forums
When I had my Moto Droid X I found out that there were documented issues with the system cache causing problems for app updates and system performance.
This came about because the system cache was not being managed properly by the apps and Operating System that used it.
Back then, I got into the habit of periodically clearing the system cache in the Droid X. I did this after doing a lot of app updates or just before a system update.
While I do not know for a fact that the S3 has any issues with it's system cache not being managed properly, I have continued my habit of periodically clearing the system cache in the S3 anyway. (Both after doing a lot of app updates or just before a system update.)
For those interested in knowing how to clear the system cache in the S3 here is the procedure:
http://www.droidforums.net/forum/galaxy-s3-help/217105-how-do-you-perform-cache-wipe.html#post2194204
Please Note: Be VERY CAREFUL when doing this procedure that you do not do a Factory Reset by accident.
Personally, I would not do a factory reset unless the update fails or I start having a LOT of issues with a LOT of apps.
After an OS update such as JB, it would not be unusual to see some apps have issues because the app needs to be modified to work properly with the new OS.
Doing a Factory Reset will not help in situations like this where the app is the issue.
Hopefully the JB update will not cause very many problems for too many of us.
I am looking forward to seeing the new features & functions JB brings to the table for our S3s.
So after playing around more I decided to do a Factory Reset (after backup). Out of curiosity I ran the Software Update and received "Unfortunately, Settings has stopped.". I wondered if root still lived after the reset, and confirmed with Root Checker Basic that root was still functional. Next, I reinstalled Root Explorer and checked the filename extensions for FWUpgrade and SDM. They are still at the renamed instances of .bak and odex.bak, respectively.
So, being this is the first time I've rooted is what I experienced after a Factory Rest normal? Seems as if an OTA push relies upon the Software Update feature and the underlying files/apps; then it will not succeed.
To make sure you still have root:
1. Make sure you have "Super SU" app
2. Run an app that asks for root, and make sure you get prompted for it. One very quick way to tell is to download "Terminal Emulator" app, open it and type "su -" at the prompt. It should pop up and ask you to grant root permissions if it's working correctly.
Worked perfectly from what I can tell so far.
I just got my S3 yesterday in the mail. I could not wait for today to open it up and set it up. I have seen that people are saying to format the phone back to factory after the update... Am I really going to have to do this?
Quick question:
I just got the update and it automatically set me to Global network mode. Should I leave it that way or change it back to LTE/CDMA?
Quick question:
Same here. Anyone know if it makes any difference being on global vs lte?
Sent from my SCH-I535 using Tapatalk 2
I am running aokp milestone 1, I have the 4.2 keyboard, the 4.2 camera, wallet, and 4.2 Gmail. Is there any reason in the world that I would want to go back and get the update?
Sent from my sch-i535 using Android Central Forums
Quick question:
I was wondering the same. Anyone know?
Change it back to LTE/CDMA it will use more battery in global mode. My friends Razr did that as well and he said his battery life suffered a little until he switched it back to LTE/CDMA. My S3 is updating to the Jellybean OTA as I type this and I plan to switch it back to LTE/cdma so I don't loose battery life.
Thanks. I changed it back to LTE.
And what do you do if your Super User app isn't working right and ROM Manager doesn't let you run backups - just get errors. I tried reflashing Clockwordmod and just got an error. Don't know what happened. Is it still rooted after the update?
DO. NOT. DO. IT!! this is the biggest mistake i have made in regards to my phone.. i loved my phone so very much (with ICS), and i was very excited for Jellybean. so, at around midnight last night when i saw on the Samsung Mobile USA Facebook page that they'd confirmed the roll-out for JB, and that it was also in my phones new updates (as an OTA), i jumped right on it. now, i am frantically looking for a way to un-do this travesty and regain the functions of my once adored SGIII. here are the issues i am experiencing (SO FAR). if ANYBODY has ANY insight, or can point me in the direction of restoring ICS (my phone is NOT rooted, and i would very much prefer not to ROOT) i would be eternally grateful.. please! i love my SGIII so much. i am actually so upset.. i plan to return my brand new Christmas present of my Galaxy Tab2 7 because i want absolutely NOTHING MORE to do with Samsung! they have destroyed all that was good and right with the nearly perfect phone, the Samsung Galaxy S3. it is NOW to the point of being unusable.
(side-note before i dive in- nothing changed when you update OTA; all of your contacts, call log, apps, settings, screens, preferences, every single small thing stays EXACTLY the same. all of my apps are working exactly the same, and correctly, SO FAR, but i've not yet had time to open all 140+ apps on my phone. i will amend this if necessary. okay, onward..)
-NO MORE linking contacts. nada. buh bye. say hello to your contacts looking like a disorganized mess. this is making a mildly-OCD person like me very upset. i like organization and structure, and this was a VERY important feature to me.
-BYE BYE BATTERY LIFE! i had my phone off the charger for, oh, 35 minutes this morning and it went from 100% batter to 76% in that time.. it usually takes my phone about 8 hours to get to that point (i have meticulous power-saving settings, and nothing changed when the update went through.. i will do more heavy settings-tweaking and report back)
-the WIDGETS! for the love of technology, the WIDGETS.. where do i begin? firstly, they take at LEAST a full minute to load upon start-up/power-on of device.. they are now VERY slow moving, slow to load, they are sluggish and well.. they just don't 'act' right. YES, i deleted them all and re-applied them. this did not help in the least. secondly, widgets such as the picture fame are now showing most of my photos as 'broken' files (showing only a black/grey exclamation point where my photos would normally be. this never once occured with ICS.. this worries me GREATLY as this could be a potential SD issue that JB is encountering..). if you attempt to select said 'broken file' it informs you 'unable to find this item'.. but, go straight to your gallery, and it shows NO broken .jpegs or photos, and shows your SDHC card as installed normally.
-using VIBRATE as an alert accompaniment within apps (Facebook, G-mail, mail, etc..) now wants to make you chuck your phone at a wall/other hard surface. with ICS, this was a useful tool.. if you did not hear the audible alert, you would feel a small pulse of a 1 sec. vibration to let you know of the impending message/alert. this has now turned into a full 5 sec. vibration, which well outlasts the audible alert.. i don't know if this would bother a lot of you, but it MORE than bothers me!
-the amount of space this app will use on your phone is.. inordinate. i hope you have the 16 gb. model of the SGIII, because if not, you will very likely not even be able to update to JB! i went to my Settings > Storage > Device Memory, to make sure my SD card was being properly recognized (due to all the broken photos appearing in my widget).. and i thought my eyes were being deceived for a moment. there is a break-down bar at the top that tells you the amount of space being used by each part of your phone (apps, photos/videos, downloads, 'misc. files' aka bloatware and OTA updates). now, before my JB update, granted i still did not have a ton of space available on the device itself (this is where my 32 gb. memory card carries most of the burden), but i know it was somewhere around 1.3 gb of FREE SPACE available.. unused.. NOW? now, i have left, after the JB update.. 789 MB. MEGABYTES, left. JB and it's 'miscellaneous files' are currently overtaking 11.69 GB of space on the device itself. that makes me want to vomit.
-(*AMENDED) no longer compatible with SYNC to computer.. it informs that the device requires an update of drivers, but provides NO solution to this issue.. i had a message appear briefly on my screen, informing my that the device was no longer recognized as a USB device, and unable to sync with Android, Google, media, etc etc.. it informs me to use Kies to download a Samsung software update. since my phone is bricked at the moment (i have NO apps/widgets/icons on my phone, no screens, no pull-down notification bar, no lock-screen apps.. nothing), i am unable to attempt this anyway.. but, i have done a bit of digging into this issue via other Samsung and Android forums to see what this error message meant, (there are even several threads here, on AC, addressing this exact issue..) and most users are informing that Kies is crashing or denying access to the actual 'fix'.
this is all i have come across, YET.. i am far too stressed out to look for anything further, as i now have a call to make to VZW. i will be demanding a swap for my SGIII as well as returning to them the 5-day-old Galaxy Tab 2 7" i just got.. shame, i very much like the Tab.. but i will never, EVER willingly own another Samsung product after what they have done here. Brava, Samsung.. releasing a half-baked version of a software just to pacify the masses? guess what? now you ARE just like Apple.
i reiterate- if you enjoy your SGIII, as i did up until today, DO NOT DO THE UPDATE TO JB. i am so unhappy right now, it is immeasurable. i had literally finally found what i had deemed the perfect phone.. and they ruined it in one fell swoop of a shoddy update that needed just a little more work.. but they gave into the screaming masses, as the conglomerates do. now, they will make us wait 6 months for an 'update' to fix all the issues with it. i, for one, intend to raise hell with my carrier. i know the in's-and-out's of Verizon well enough to know what to say and do to get use out of my 1-year manufacturer's warranty. in the meantime.. somebody.. ANYBODY.. PLEASE, tell me there is a way back out of this awful rabbit hole?! PLEASE!
(*AMENDED) after 3 and a half hours on the phone with VZW tech support yesterday, i was informed that for the past 3 days, they have been inundated with calls from SGIII and NoteII users with my EXACT same issues.. phones, well for lack of a better word, 'bricking'. after a failed master system reset, and a failed remote reset, they had to sent out a replacement device. luckily, i will be getting ICS back.. when i get my replacement device in 5-7 days. you can be sure i will absolutely NOT be attempting another OS 'upgrade' to JB! at this point, after flashing my device and attempting a master reset, it only worsened the issues. my phone has no more icons/apps/widgets, no more screens, no more lock screen functions.. it only shows the background image upon being powered on, not even showing the drop-down menu bar or any of the icons that should be in it (time, 3G/4G, battery, charge percentage, notifications..). i have no idea exactly what went wrong here, but this is clearly something to do with a corrupted JB OS, as was confirmed by one of Verizon's tech support managers. the bottom line is, these updates ARE causing major damage to many phones, and not even working correctly to begin with. to me, this is not worth the couple extra features it comes with. i went from being so very happy with my phone, to absolutely hating it, and Samsung, and everything they stand for.
I absolutely love JB on my S3. Best decision I ever made to upgrade.
Sent from my Galaxy Note 10.1
Although you won't root, your best solution is either cleanrom 5.5.1 or another similar.
Understand product development when a phone first comes out optimizes everything. People then insist on the latest update, and this is more about compatibility.
The great modders then tweak and throw out the bloatware.
Samsung is not really to blame. They build great devices.
gurusdex
