Verizon LG G2: Word on KitKat?
Tried dozens of times, the updater says it's checking my device info, then after the progress bar fills 3 times it quits and my only option is to close the program. My device never appears in the list and the update button stays grayed out
I have vzw kit kat thanks to today's update. And yes tap to pay is there. uploadfromtaptalk1397785514963.jpg
Sent from Bad Azz VZW LG G2 Cyan Tapatalk
Not working for me...have a white g2...does the same thing that AZDroid is experiencing.. I have windows 7,does that make a difference?
I tried on Windows 8.1 and Vista, no luck on either
But others have had no problems with 8.1, frustrating
I was able to update by going into settings and checking for update manually. No glitches so far
sellhousefastmke
