somenothingness
- Dec 3, 2012
- 81
- 0
- 0
LG stated, in chat anyway, that the update is only available via OTA, that the update tool. doesn't work. sigh...even they (or some of them) don't follow forums huh?
What windows os are you running? For those wondering I have the black phone. When I attempted to download the Verizon upgrade assistant on my windows 8 PC it started to load and at the end aborted due to a corrupt image. Windows 8 blows, I'm sure any os but 8 will do the trick.
Sent from my Nexus 7 using Tapatalk
I do have TWRP as my recovery... so what do I do? And thanks for your response!
The new 8.1 update. The upgrade assistant installed fine, no corrupt image or anything. And it runs, and checks my device, but never adds my G2 to the device list or show an update for it. I've seen others with Windows 8.1 who said it worked fine for them.
In general I've had no problems with Windows 8, still won't say I really like the metro/modern aspect, but the latest update added improvements
Are you using your factory lg USB cable? I could not get it to recognize my phone in that list until I got the factory cable.
Over in the xda forums they have a "back to stock" tutorial using a tot file. Only issue you will have to flash software 11a then ota 12b to get your phone back to pure stock to take this 24a kitkat update.
Why is everyone in such a hurry? The actual OTA should be out in a few days at most, and it'll me much easier to install. This is identical to the leaked rom on XDA right? In that case, I think its much better to install xdadebb's custom rom with a fully patched root/recovery, for those who are rooted.
Yes, I dont know of any other way to flash the stock recovery. Your update will surely fail, that is if you dont brick.
Big Pimpin' Big Red's LG G2
It's new, other people have it and I don't. Not fair, I want it now! Hah.
I rooted my last few android phones, but nothing on the G2 has seemed bad enough to warrant it for me so far. But there are a few apps and things that are kitkat only that I want to play with so I'm excited to get it.
Ok thanks very much for the info!
Just remember when you receive the ota you will brick if you try to install with twrp as your recovery, you are going to have to go back to pure stock sometime.
