Verizon- pie update?
Verizon did support it and I'm sure they still do yet I can't find it in the settings menu anywhere I do have a notification that asks me to "tap here to confirm or update emergency location blah, blah, blah... I do that and after a bit it says "Unable to perform requested operation at this time. Please try again later." It's definitely not in the drop down notification panel. Besides that everything else seems to work. :confused:
Open the Samsung Phone app, open settings, turn on WiFi calling.
I didn't think to check there... it's there but it's still not validating my emergency address. I've had this issue before and had to do a factory data wipe and make sure the first thing I activate is WiFi calling. This sucks! :(
What happens when you turn it on, and then select "Update Current Emergency Address"?
What happens when you turn it on, and then select "Updated Current Emergency Address"?
I get the spinning wheel that says "Loading, this may take a few moments..." then it craps out and I get "Unable to perform requested operation at this time. Please try again later." Also worth noting that it worked flawlessly before doing the SD card update. So something with the update upset the turnip cart.
Try booting into recovery and wiping the system cache.
You have a prepaid card Verizon or Verizon card?
No...try maybe restart phone and enable the wifi calling again
I've restarted once already, I'll try again. Also I have the option to turn on WiFi Calling, it's just when I either click the slider to turn it on I get "Loading, this may take a few moments..." then it craps out and I get "Unable to perform requested operation at this time. Please try again later."
Long press the dialer app then tap info , from there clear cache , force stop it then check again the enabling wifi calling.
Did the restart with no luck, force stopped the phone app as well as clearing the cache, still no luck. Keep ending up with this error
You probably have to see a Verizon store for this solution.
Nah, I just need to factory reset and make sure that the first thing I do is turn on the WiFi calling feature. Or I might try at my gym in the morning, when I'm off my wifi.
You can try factory reset , but I don't think it will help hope I'm wrong .
Otherwise try resetting APN in settings and then connections or even take the sim out and put it back in
z1hallitsee
