Verizon pre orders
I went with Samsung and got a unlocked Ultra Sky Blue 512GB trading in my Note 10+4G edition for $425.00 off. It came out to be $874.99 and $932.95 total with the taxes.... Still cheaper then what Verizon was offering...
I got the black 512gb ultra. Is it me or were there hardly any freebies this time? Feels like in years past there were a ton of free things.
Also Verizon only wanted to give me $89 for my near mint Note 9. I'll either keep it for backup or sell somewhere else for that little.
Can't wait to finally get a new phone. My note 9 has been incredible I will say.
I'm gonna assume I can transfer all of my music and pictures from my SD card to the ultra pretty seamlessly as well?
I did the same. I'm holding on to my Note9. I'm not excited yet because I truly hate setting up a new phone.
Are you going to do Samsung Switch?
I was hitting refresh on Verizon as soon as the Samsung unpacked began. Got in very early and ordered Ultra in phantom black 512gb.
Then got over to Amazon and ordered my Spigen Tough Armor (my case on last two phones).
The case arrives tomorrow so I get to look at it for two weeks while I wait for the phone to arrive.
I usually buy the VZW kickstand case. I wonder if they have one this time? No option came up to purchase a case nor charging brick during my purchase.o
I think so. Hoping it works seamlessly
I recommend using the cable when transferring over everything via Smart Switch. Had a bad experience a couple of year ago just using Wi-Fi to make the transfer. Unfortunately I factory reset my old phone before checking to make sure everything transferred over to my new phone. Used the cable last January and had no issues.
I used cable the last time. I don't know if the program on my computer is still good.
Good to know you used the cable to transfer. Using Smart Switch on a computer can also be dicey. Learned the hard way on that one time as well, as it transferred over everything but my calendar.
Actually by "used the cable" I meant the computer rather than wifi. Is using the cable just a USB c to USB c cable or something special?
I think I lost my mind momentarily. Whew! They were going to make me go to the $90/mo. And carry that phone payment for 3 YEARS. PLUS, I think you have to put insurance on it? No, no, no. My Note 10+ in a new case is looking okay for awhile longer. I sure would like that 512 White... 😎
Yes, I actually think the best way to transfer over everything from your old phone to your new phone is using the USB type C cable to connect both phones and run it.
Never thought of that. Would that actually work though??
Within Smarth Smitch. You just connect the two phones via your cable.
No way to chose what to send? I don't want it to copy contacts. I sync contacts through Google.
There is no method to transfer app data right?
The app will ask what you want to transfer. If you wish you can click on any of the choices, to include contacts, to not include that item. On apps you can choose which to copy and which not to.
georginaggrosso
