sixty_four
- Nov 29, 2011
- 510
- 3
- 0
Re: How to get back to previous version and radios
I successfully downgraded VRBMB3 to VRBMB1. 4G speeds are great again and I'm reluctant to apply the new VRBMF1 update that Verizon is pushing out.
Has anyone still on MB1 taken the MF1 plunge yet? I'm going on a trip this weekend and don't want to dork up my phone before so I deferred MF1 until next Monday.
	 Your choices are to let it download and install immediately or to defer it for a maximum of 5 days
 Your choices are to let it download and install immediately or to defer it for a maximum of 5 days  I would suggest you try to plug your phone in one of the USB ports in the back of your computer, as those are more reliable and see if that works
 I would suggest you try to plug your phone in one of the USB ports in the back of your computer, as those are more reliable and see if that works  also, check the wire too if it still works. One time I tried to flash something using odin and it fails because the wire I used was flimsy and unreliable
		 ), but I'll look into rooting and preventing OTA if I can roll it back.
 Facebook
Facebook Instagram
Instagram
