Verizon S7 edge software update
My guess would be the update has problems if its updating certain packages that are disabled? I just know the app developer recommends it, not sure if there is a drawback to not enabling them
Re: Update from Verizon
I have noticed significantly slow fast charging, also made sure to check fast charging was enabled in settings.
S7 Edge Titantium
Update turns Marshmallow into Lollipop because Verizon needs to be always 3 updates behind. Just kidding.
S7 Edge Titantium
My fast wireless charging switches down the regular wireless charging after this wonderful update. :(
I tried my fast wireless charger as well as using the wire. Both of them stay fast charging.
Anyone thinking of doing the update and has adoptable storage enabled, I did the update with no issues.
How's adoptable storage working for you? Does burst mode in the camera working for you after this update?
I am holding off as long as possible. Seems to not be a useful update and may close a root vulnerability.
Probably a stupid question but how do you tell if the phone is charging in fast mode or slow mode?
I'm thinking that you just look under battery and the fast wireless or fast wired options should be blue when plugged in if fast charging is working. Mine stays white
tahirmehmoodkhokhar786
