Jvazquez930
- May 10, 2013
- 111
- 0
- 0
Who's in the PA club?
Its weird how i live in NJ and mine is in Memphis instead of it coming from PA
12.99 vs 34.99? Nooo.
Posted from the S7E Chrome™ on Big Red
 hopefully we will all see some movement by tomorrow.
 hopefully we will all see some movement by tomorrow.If that's your primary concern then sure... Buy it from Verizon.Yeah, but I can't swap it out @ Verizon store if there is a problem
If you are clumsy, yes. It has a 80% survival rate at 1.6m. Also certain material like sand will most likely scratch the screenWith all the hype around Gorilla Glass 5 on this phone, is a screen protector really necessary?
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU5333966Can you post a link, please?
Wait, Quick Charge 3.0 works with the Note 7?
But i have used a dozen or so Samsung chargers... None of them ever failed. And I have enough spares that if one were to fail, then I can wait for a warranty replacement.
	Safe to say that they are going out tomorrow and show up on Friday?
Does it work?//uploads.tapatalk-cdn.com/20160817/3b207bbac565a9b4cee428d860eb9492.jpg looks how crinkled and nasty ,the white turned yellow with use
It looks to be a pretty old cable, but if it is less than a year then Verizon should replace it under warrantyNot 100%, the battery drains faster than it can charge.
