Very pleased with new firmware upgrade
What other issues does this fix?
I'm wondering about the issue of no SMS notification sound when automating sound profile changes (NFC tag or automatic task scheduler).
I can't imagine I'll see it any time soon here in Canada on Telus.
Any chance anyone noticed if the talkback compatibility with other programs (lightflow) was addressed?
Anyone able to answer this? I really hope they got this fixed!!! I'm sick of hearing "The checkbox is currently checked" when using the gallery.
I got my second update for my s4 yesterday and now I can move my apps to SD card.. Yes you heard it right.. Apps can be moved to SD card now. I m in INDIA
cool. did you notice any change in the performance of the apps? it can be moved? so if i first install it into the internal memory there are options to move it to the SD card?
No change in the performance of apps moved to SD card. All are working fine as earlier. Secondly, please note you don't get option to install apps directly on SD card ( I haven't find such an option till now, may be it's there, not sure) but you can install on your device and then you can transfer it to memory card. But it IS an important improvement.
Awesome to hear that it is working as planned. Samsung has done a spectacular thing by staying loyal to their customers needs. :thumbup:
Sent from my HTC6435LVW using AC Forums mobile app
Yes you can...but not all applications...can't move native ones
I'm in the US & got an update a few days ago & now my texts won't send when I'm on wifi. Any ideas??
Prince08900
