- Feb 4, 2011
- 1,660
- 125
- 63
Has anyone had any problems with vibrating not working right? Mine barely works when I get a phonecall. I've been checking the settings but I don't see anything missing.
Did you have certain app disable for an alert? You can control how each app will notify you.Has anyone had any problems with vibrating not working right? Mine barely works when I get a phonecall. I've been checking the settings but I don't see anything missing.
My phone is set to vibrate when I get a call. It doesn't. My settings are the same for the flip 5 and my brother in laws fold 5. Well as far as I can see that they are. Mine won't vibrate.Did you have certain app disable for an alert? You can control how each app will notify you.
It wouldn't surprise me if they have disabled it.My phone is set to vibrate when I get a call. It doesn't. My settings are the same for the flip 5 and my brother in laws fold 5. Well as far as I can see that they are. Mine won't vibrate.
But I can't even go into testing mode either. That's weird. I'm unlocked but on Verizon. Did Verizon disable *#0*#?
Didn't think about safe mode. I'll try thatCheck this settings for calls and also put in safe mode if in the members app/device care diagnostics menu shows ok for vibration![]()
Didn't work. I think it's hardware, which means I'm going to have to get it checked out to get fixedDidn't think about safe mode. I'll try that
Yeah definitely, keep us postedDidn't work. I think it's hardware, which means I'm going to have to get it checked out to get fixed
