Video of HTC One drop test
Just a heads up to all you brave ones out there thinking about going naked, please don't:
Please learn how to properly share images. The correct way is to use your own hosting, such as Imgur, instead of simply copypasting links from other forums...
Fixed specifically for you. Maybe they'll work fine now.
Yeap, it works. That's a pretty bad physical damage - looks like it fell from high height or was hit with a hammer or something... Any other smartphone can be just as easily damaged, so if you tend to drop yours a lot or throw them against walls - investing in a good case (which might not protect the glass and might still be useless) or extra insurance from local cellphone provider is always a good idea ;-)
Personally I just try to be careful - all of my iPhones still have their original glass surfaces, even though the only "protection" I've ever used were the transparent stick-on "skins".
It was dropped. My main concern for this phone is durability, you can see most of that grill is loosened.
Does anyone know if you can buy grills separately?
The problem is going to be identifying what solvent will rmove the old glue withput damaging anything.
Sent from my SPH-D710 using Tapatalk 2
Those pictures undermine the drop test you're parading around elsewhere. Those grills are not loose and have not come off. In fact, it looks like the 'separation' is just the metal deforming from impact.
Oh and NEWSFLASH: If you drop your phone, any phone, it will break or be damaged!
Sent from my HTC6435LVW using Tapatalk 2
Single data point extrapolation FTW eh?! Jebus.
No. Now two points. And the only claim is that it COULD happen. Not that it will or not even that the incident rate will be high. If you see.something happen once, its perfectly acceptable to single-point extract the fact that it could happen.
Just drop it before you get accused of being a troll because you're speaking out against the popular opinion and JHBThree follows you from board to board looking to quote you.
It's not pretty.
jmarshallcleaning
