VM670 update?
If no one has done this by monday I will, but out of town now.I had an optimus drown last month so had to get a new one, just gets no cell signal. I will revert back to fully stock and try. Also I was running a hybrid PRL, should I change that back too?
If this is worth anything, nothing I can find about the update on the VM facebook wall/discussion area. Still, may be too early.
-K
Oh dear, here we go. It's downloading. I'm pretty sure it will fail to extract it, but lets see.
If its a long update then I'm pretty sure its gingerbread, but if its quick it could be something minor.
Are you trying from recovery? My phone is recognized by LGMobile update via recovery. Mine freezes on "Checking the module" from recovery.
"Updating is not possible any longer due to a fatal error while the LG Mobile Phone Software Update."
Gotta love engrish
It identifies my phone correctly as LGVM670
Original firmware is 98 megs. This is 101megs.
That's a fairly substantial update size for something to be just a prl update or a fix, no?
-K
Why can't someone play dumb and email the right person at lg and just ask for the file?
Mmarz..when you tried was your phone fully stock our customized in any way?
I called LG they are as confused as VM. VM said no update. LG said there is an update then said their isn't. I tried to get info on on it.
Dangit I just returned my V for a new one this morning- I flashed Harmonia the moment I opened it ;) Not sure what I am more excited for... a Harmonia update or a possible GB update, hmmmm.
This is driving me nuts. I could see the update just fine on a 2.2.1 rom (Nameless v1). But when I go back to stock/stock recovery, I can't get the program to see my phone.... Yet, adb see's it. It makes no sense. Crappy, crappy drivers...
Beboomo
