voice commands
Re: Ok Google / microphone
What was your message?
Smartphone, Samsung Galaxy S5, Lollipop 5.0, Verizon network
S voice
I used to have S Voice on my smartphone. I don't know what happened but it's not there now. I'm looking for it because the microphone is not working properly. Help. Thanks.
Re: S voice
I take it you looked in your App section.
Re: S voice
Found the problem. Somehow, Google voice got turned off in Language and Input. Thanks.
Missing search icon
What happened to the search icon in the forum thread? Thanks.
Re: Missing search icon
Using Chrome browser and, "Search Forum", and, "Search Thread", show up if you use, "Request desktop setting", in menu, (3 dots). If your browser has a desktop setting, try enabling it.
I was referring to the FORUM search icon. It was there just 2 days ago. I'm using a smartphone. Chrome does not have that setting. Thanks.
I still can't find it. Thanks.
Search icon
Can anyone explain why the Search icon in the thread section has disappeared? Searching for previous threads was a very important and useful. Remember, I'm using a Android smartphone. Thanks
Re: Search icon
What are using to search or view threads? Ac app, tapatalk, or web? In the meantime I will move this thread to the site discussion forum.
Re: Search icon
I'm using Android Central.
Re: Search icon
If you are using web/desktop view there should be a pull down above the first post to search the thread. Do you see that?
Re: Search icon
I am not using the Web. Never have. The search icon was there a week ago, and has been for 2 years. What happened to it. Thanks.
Re: Search icon
If you could screen cap it and point out where it is missing, we can take a look. Thanks!
Re: Search icon
Here's the screenshot.
Re: Search icon
So you're saying the search icon at the top right does not display for you anymore?
Re: Search icon
Not following you. You mean the search icon that's in the upper right of your screenshot — and is very much still visible and working in my app as well right now — is no longer there? Can you show a screenshot of that, please? Very weird.
Re: Search icon
The screenshot I sent, I admit was useless. Here's the one I should have sent.
liquidsnake757
