Voltage control settings
Gotcha... thanks. So, how do I use the info? Lower the voltage in the steps that are used most?
Sent from my Fascinate via Tapatalk
yah buddy, than play around with them with apply for now, dont save as boot till u know its good for u! Glad to help with the MIUI bug, I cant wait for that to be fixed as that is my fav locksceen
Did that. Gives me the "saved to ... " confirmation, but it doesn't keep.
My phone talks to computers.
you could clear the data in the program try that first, do this second, in recovery clear voltage setting think it is in advanced you could try that than save again and see if that helps. as last resort delete the program and re download in market
Hey guys - simple dumb question I'm sure, but I'm trying to run the Regina 3D launcher, and I'm hoping the boost of an overclock will help out with the lagginess a little bit, but I'm not sure how. I've got Voltage Control, gone into it and upped the max to 1200, but when I check out CPU spy, it shows the 1200 setting as not being used. Am I doing something wrong? Oh - and prior to existing Voltage Control, I save the profile (although has the feel of just saving the profile and nothing actually being applied). Thanks in advance.
I think there is a bug in the voltage control app and you will have to reboot before your overclock settings will take effect.
Reactions: Brettdacosta
Cleared program data with no result.
Wiped voltage settings to no avail.
It won't allow me to uninstall VC since it's a part of UKB2.0
Ideas? It was fine until I restocked, updated and rebooted UKB2.0
Flash the no kernel version of UKB it doesnt come with it I assume since my didnt, than download from the market. If you want
Hmmm. When I work on wiping data to flash UKB no kernel, it freezes when it gets to "formatting /sdcard/.android_secure/"
What does that mean? Something bad, I bet. I pulled the battery and retried it a few times, but to no avail.
just let it go.... don;t battery pull, it hangs for a little while, but it will finish
Reactions: adamklo
fidsomedia
