VZ is pushing ED04...
Landshark,
I thought that Comm ROM has a modem because under highlights it says ED01. Trying to keep up with all this stuff so am I missing something?
Comm Rom is a Froyo based Rom. It works with the kernels in conjunction, basically your operating system. The modem is something different that comes separate from the comm rom.
Jus t did the update using the steps here and it worked just fine. [MODEM][ODIN][CWM]DL09, EA28, ED01, ED03, ED04 modems without ridiculous 100MB OTAs
have 3 Fascinates. 2 OTA just fine. 3rd is quite stubborn :-) Server Unavailable.
I upgraded it to ED01 from EA28 via an update.zip I found. Worked fine.
(copied it to root of sdcard, rebooted and update away. )
Anyone know where this 'update.zip' is so i can get Mr. Stubborn from ED01 to ED04 ???
Thanks!
Thanks!
Look at the link right above your post. It will only work using CWM 3. It is an edify script.
Landshark,
That ED01 just means the ROM is based off the ED01 build. ROMs do not include modems. Custom ROMs available here contain the ROM, kernel, and recovery (CWM), modems have always been separate. The ODIN packages contain modem, ROM, kernel, and recovery. Although just recently I started putting ODIN packages together without modems due to not having separate ODIN flashable modem files for the ED01 and ED03 modems.
FYI.... I had to go back to stock DL09 today and when I did the upgrade path it went to Froyo with DL04. Awesome! Now to root and get back to Comm Romm. :-)
Thanks!
There is no update.zip for ED04 right now. We'll see if comradesven can work his magic again and provide a zip file to update from ED03 to ED04, but as of right now the only way to get to ED04 is through the OTA. Make sure you have wifi off as the OTA is done over 3G, and also make sure you are not rooted. Either of those will interfere with the OTA.
It's out over at XDA just flashed it.
http://forum.xda-developers.com/showthread.php?t=1097355
I am wrong again and you are right as usual! This is why I sign the praises of the shark man! Good catch!!!
Oh, I believe you caught me in a slip up before too. We're all capable of little slip ups, and I've been wrong too many times to count and freely admit it. Besides, I knew yours was just a type because you just typed DL right before then and it was probably still on your mind. :cool:
i looked at those zone files and all the model files contained with in are small in size compared to say ec01/eb01/dl09 modem leak tar files. is that right?
Unable to flash from ED03 to ED04, says failed. maybe it'll work from ED01 to ED04....
Read the descriptions on each of the files. None of them say ED03 to ED04. There is an ED01 to ED04, but in order to get to ED01 you would have to use the method in the linked thread which would involve flashing the DL09 modem then the file to go from DL09 to ED01. So just ODIN the DL09 modem file, then flash the DL09 to ED04 zip file in CWM 3.0
the "ED01toED04_modemdelta.zip" files, is that just a patch to get the edo4 modem? i notice the files sizes are small
Yes, all the zip files in that thread are just patches to get the desired modem
DanishDanuu
