VZW Rockband APK
the first one would have worked but it was faster to download it to pc thanks a bunch for the freebe app
I can't get this to install on my dinc. Starts to install then errors out. Tried downloading it twice same issue. Running stock 2.2 no root. Any ideas.
Works great for me. Mine errored upon installing but still installed. Try keeping/removing the stub before you install the full. The install takes quite some time, so be prepared to wait. Other than that, it's absolutely great!
(On a side note and a bit offtopic) Does anybody else have more trouble on easy than normal and hard? Seems to me like normal and hard have more leeway to timing (could just be im pressing at the same time, but the frets are moving faster) than easy does. I can get long streaks on normal and hard, but easy always seems to screw me over by hitting a fret too early.
everything DL'ed and installed with no errors, but when I try to run it, I only get a black screen.... any help? I have tried to re-install it (successfully) but am having the same result.
Thanks!
I Have EVO 16BG Rooted Second Gives Error. I Have MT4G Edition On Phone. The App Says Install Sucessful But Wount Opem
Installed on DINC and D1 and installed second file it wont give me the option to launch it.
just out of curiousity, i tried it on my xoom. no dice, fc as soon as opened. dont know if anyone was wondering or not.
same here...have mytouch 4g with stock o/s. got the 194 mb file to install with no problem, but upon opening the app theres a black screen that says rock band at the top but it hangs for about 10 seconds and then exits to the home screen.
just thought about this...could a possible solution to any kind of problems (including the one i stated above) be due to an existing rock band app installed on the device already? i.e. on the mt4g, it comes with a demo version of rock band. could these be kind of interfering with eachother? just a possible thought, idk. btw, the original pre-installed demo version still works just fine.
Hi, I'm very new to the world of smart phones. Does one have to root their phone before installing the app? I tried to install the first part to get to the second part, but the install failed.
hello there, i'm a noob when it comes to android and all that. i've been looking for a rock band game for android, i have a HTC Desire Z. i tried downloading the app from the link on the first page, and when i was done with it, i installed and it downloaded a new rock band app. for some reason, the people here said that it was normal and all so i just continued with the process. when everything was done and with the newly downloaded app was installed, i tried opening it and all i got was a black screen. i've been waiting for something to pop up and nothing seems to pop up. have i done anything wrong?
When I click on your link I get an "error 404 cannot find" message.... would you be willing to send me the apk directly?
That link is very old and the apk no longer works. You can download Guitar Hero from the Play Store.
