VZW Silicone Cover
I like these over the buttons. I usually don't but it still provides the keys with plenty of play to click properly.
It looks like they'd be easily pressed on accident though, which is why I rather get rid of them all together. (or even being pressed constantly due to the pressure)
Just got one today from a VZW kiosk. Was debating whether to get a case at all as after a month I don't yet have scratch 1 on my Inc, but accidents will happen. The fit is excellent, and on first glance you don't realize it's a case at all. It adds a little bulk but I REALLY like that it protects the camera lens that was just jutting out there before. Phone sits flat on surfaces now and I feel like it would take a serious drop to damage it. Quality case.
It's a great skin. Fits perfectly and all buttons are very responsive. I highly recommend it!
Also recommend
I too have the silicone black case and it has been great. It almost even enhances the functionality of the buttons as the hold button on top and volume rockers have a little bit more of a click to them which I like. Couple it with a screen protector and the only uncovered parts are the 4 touch buttons and the optical wheel. but what do you expect.
the body glove case is the best get it. it has a rubbery grip to it and come with a belt clip, it also snaps together tight.
I had a red silicon case on mine since day one. Today I decided to spend the 13 bucks and also grab a black one. I should have gotten black from the start. It looks so stealth.
The only issue with this skin is the hole for the headphones jack is not big enough. I had to grind the whole a bit bigger on both. I did a lot nicer of a job on the new one. I simply took some 200 grit sand paper, rolled it up and ran it back and forth through the whole to make it slightly larger. I finished it off with some 2000 grit to smooth it out. Works perfectly now and doesn't look all chewed up like my old red one.
I have found, being left handed and all, that before I got this case, I was always pressing the volume keys by accident. Since I put on this case, that is not a problem anymore.
Don't have my Incredible yet, but I read some good posts about this cover:
Amzer Argyle Skin
Design isn't for everyone, but I think it adds some style to the phone. Amazon carries it as well (free shipping, free 2 Day With Prime), but is currently out of stock.
I bought the silicone "condom" made by HTC from BestBuy. It was a little expensive, but liked the form-fit showing off the design of the back cover. No complaints!
I have the black that fades to red snap on case it gets lots of looks,and I have the black cover that slides into the holder with belt clip. Both of these are sold by Verizon.
trgrestaurant16
