Wall Charger Info...
billykac
1,339
What are the specs for fast-charging on the Note 8? Is it USB C PD-compliant?
I have a Google Pixel wall charger that will provide 15 watts (5v @ 3 amps) and 18 watts (9 volts @ 2 amps). I am quite sure the N8 will negotiate a safe power level if I were to use the Pixel charger, but would the Pixel charger provide optimum power for the N8.
A bit confused!
The Samsung Note 8 charger in the box has two outputs 9V @1.67A 15 W and 5V@2A 10W.
So I am not so sure how the N8 will handle it.
I don't think you'll do any damage using it to charge the Note 8 but if you'll get fast charge or not I don't know
