What do you like most with ICS?
My favorite feature:
Settings -> Apps -> All -> (Any/All VZW Apps) -> DISABLE
No more in menus, app drawer, and no asking me to update in the Play Store stupid crap I will never use!!!
Oh yeah.....I went buck wild on the "disable" useless apps!
Sent from my ADR6425LVW using Android Central Forums
That's the bad thing about ICS. You can't separate the ringer and notifications like you could on GB. That's my only gripe. There is only one app I found that worked. It's called ICS Enhanced Ringer Control. It's in the market.
Strange...I quoted someone asking about this and it didn't quote them and I don't see the post anymore. Oh well, I'm probably tired. I'll leave this post for informational purposes. :)
Sent from my ADR6425LVW using Tapatalk 2
You can browse the net without cookies and history is automatically deleted upon exit of the browser.
My wife and I share a tab2 and I used this feature when I was shopping online for a fifteen year anniversary present for her.
Sent from a Rezound with tapatalk 2
How do we find the settings for this? Please and thanks!
They are part of the Chrome browser, you have to install it from the Play Store.
What apps do you recommend disabling???? A list if possible??
This is a good list... Don't disable anything with a "com.xxxx" name though, and beware disabling anything you don't see in the App Drawer, if you get too crazy you will likely be headed for a Factory Reset since if it fails to boot or you disable something that is required to get to the Settings menu (like something related to touch input), a factory reset might be your only option.
What are some good apps to disable?? I disabled most of the Verizon apps I believe but I'm not quite up to 20 Lol..
Nevermind I guess I was late in asking that Lol. Thanks!
BTW Face Unlock kinda sucks in regular light... I do like swipe away notifications, disable apps, new folders (even tho u can only fit 16 apps), multi-task, launch dock, black notification shade, data usage (especially with VZW disabling the widget.. bastards)..
I still gotta get used to Chrome. Doesn't it have a Home screen?
Also, I thought Beats Audio was gonna be enabled for all music players. Was I wrong??
I like Chrome. I like the new launch bar. I like swipe notifications. I like multi tasking. I like the usage panel, though it is not even close to what Verizon says I am using. I like the new look of the folders, though I don't like that there is now a folder limit.
Uhhh ohh. Here it comes...downloading now....
thattoiletguy
