What do you like most with ICS?
I downloaded it to check it out and when you press the widget it just opens an information screen on how to install the widget, what did I miss?
Long press on home screen and select widget. Scroll down to slider widgets and select the one you want. I like the4x1. It will appear on your home screen. Tap the volume you want to change and when the slider spears make your adjustment.
Sent from my ADR6425LVW using Android Central Forums
Open chrome, open settings. Choose incognito Window if you don't want to permanently change the settings or just go through the settings and uncheck things
I like that you can pull down the notification shade on the lockscreen.
For those who want separated volumes, try Slider Widget. I've been using it for months.
https://forums.androidcentral.com/e...=de.hinterhofapps.sliderwidget&token=Z2wJqX5U
I just downloaded this but it looks like the notifications and ringtones are linked. Did I miss a setting that unlinks them? I love the widget interface but I need to be able to control the notifications and ringtones independently.
Sent from my ADR6425LVW using Tapatalk 2
Swipe notifications, like the multitasking with swipe close,disable, the cool transition effect,folders, everything.
Since I'm used to stock I tend to hit the phone button thinking I'm gonna open apps haha
It totally just worked for me...I didn't do anything extra and it works..
I got some Ice Cream! I got some Ice Cream!
I feel too dumb...whole time that's the media n.ringtone I was thinking was.notifications...hey... This ain't what I wanted ...however I like it... Guess imma have to.purchase ics enhanced ringer control ..now that work perfectly two day trial period ..not really expensive...just went for what I.thought worked & was free... Ok...ICS enhanced ringer control..I'm on my way back!
I found another ringer/ notification unlinker that had nice widgets and you can set profiles. I don't think ERC has profiles. The one I found its Audio Control. You have to unlink the runner and notifications in settings. I tested it and it works.
Reactions: lilmyssSlim
My bad. I thought it separated them. Still like the widget.
Oh its ok..lol.. I just new I had it on & poppin! But ICS ERC works perfectly for a low price and one time fee of just $2.99 ..yikes! $2.99....Geesh...time to crack open my piggy..jk.. thanks though ok...cuz I still like slider
kalikama1
