What does everyone use to customize cm7
The Optimus 2X theme used LauncherPro but.....I could not figure out how to make it work, it has the 4 icon dock and then LP's dock sits on top with icons on top of each other. I could not figure what else you need to download for transparent icons.
my dumb self figured out that far after i edited lol, but now im having the same issue as you.
How difficult would it be to remove adw launcher from the rom completely and replace it with another? I know Ti backup lets you remove some system apps but haven't played with it yet. (don't know what I'm doing but thanks to nandroid backups I'm just take a stab at it and try to remove the file manger and fm radio first)
Sent from my LG-LS670 using Tapatalk
You're rooted. Install the home replacement you want then delete the adw apk from the system/app folder. That's what I do. I like Go Launcher better. Just make sure you install the other home first or you won't have any home at all. Lol
Sent from my Drew Stable CM7/ XioniaRedux lg-ls670 using Tapatalk.
I can't find any cm7 themes that look as good as the theme team's reborn ones.... All the good ones are hdpi....
awesome...thats what i was hoping. thanks.
aimalee
